Smeg DWI612 Not starting program
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Smeg DWI612 Not starting program
  • #16500
    adavison1974
    I have a smeg DWI612 dishwasher and it does not seem to be starting its program. When selecting program its seems to empty dishwasher then fill then does nothing. You can here it open the soap dispenser but nothing happens after that. I tried putting it on a number 1 program. Its emptied filled then nothing. It beeped at the end of the cycle but did nothing. HELP PLEASE. 😡
    #170126
    gegsy
    Re: Smeg DWI612 Not starting program
    Sounds like a faulty or jammed re-circulation pump.
    adavison1974
    Is that a costly repair?
    #170128
    Possiblities:
    1) Pump jammed by blockage – no parts required – strip down and clear. You engineer will bill for at least an hour – if it’s integrated, an hour and a half unless you remove the appliance from the housing in advance.
    2) Motor failing to start due to capacitor failure (Can you hear a faint humming?). Capacitor £15-£25 depending on exactly which one required. Labour as above.
    3) Motor failed. Nasty – certainly over £100 for pump, labour as above.
    However, SMEG is a decent enough brand, so worth having investigated. Do check out the labour rates when you make your call to the engineers.
    Click the link below for an engineer in your area.
