All I seem to get at the moment is either these or the Diplomat variant with weird faults and no code.
This one is beeping twice and trying to start (ie drain) for a second, then dead for three seconds, then same again ad infinitum.
They have reported door sticking and the facia needs replacing (lugs at top of lock unit broken) but I can’t see that causing this fault.
Reset the board and the same fault happens when you select the reset rinse prog.
Anyone had a similar fault 😕
TC
