my dishwasher a dwi612c has given up the ghost.when you open the door the fourth l e d from the left keeps flashing.nothing else happens.this code is not in the manual.when you close the door you get two beeps then silencei have tried to reset via a thread from another posting,to no avail.it will not allow you to change the program mode.any help greatly appreciated
It’s not a recognised error code. If the reset procedure has not worked you will almost certainly be looking at a computer board failure. As these are horribly expensive you would be advised to get this checked professionallly before making an expensive mistake.
Check Repairs@ or Directories for a UKW repairer in your area.
I have deleted the duplicate post, once is enough.
