SMEG DWI612C Dishwasher Door Lock
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts SMEG DWI612C Dishwasher Door Lock
  • #75862
    oakleyjo
    Customer has a SMEG dishwasher with a broken door lock. The label is worn but we managed to work out it’s a DWI612C. However, it seems there are two possible door locks for this model dependant on serial number. As far as I can tell the serial number is 102550, though I’m not sure about the first 1. Can anyone help identify which of the two locks is the right one for this serial number?
    Thanks,
    Jon
    #396419
    Re: SMEG DWI612C Dishwasher Door Lock
    697690139 is the early version and clips into the control panel itself while 697690184 is the later version and screws onto the stainless inner door.
    If it is the earlier version then you need to check the control panel itself is not broken as they often brake off the lugs the door lock clips into.
    #396420
    oakleyjo
    Thanks. Guess I better go take a look before ordering any parts !
    #396421
    oakleyjo
    It is indeed broken lugs on the control panel which is the problem so that will need replacing. Is 763735661 the correct part number for the control panel facia with the lugs?
    Thanks,
    Jon
    #396422
    oakleyjo wrote:It is indeed broken lugs on the control panel which is the problem so that will need replacing. Is 763735661 the correct part number for the control panel facia with the lugs?
    Thanks,
    Jon
    yes that’s the one.
