SMEG DWI612C Dishwasher – Error Code E6
Home Forums Public Support Forums Help And Support Dishwasher Help Forum SMEG DWI612C Dishwasher – Error Code E6
  • #43897
    gsr36
    Hi Folk,
    I’ve got the above SMEG dishwasher which has just reported the Error Code 6 which says the dishwasher fails to drain)
    I’ve tried cleaning the filters and also the reset (which I found in this site – thanks) but still no joy.
    According to SMEG, there are 3 causes for this fault :
    kinked drain hose
    Pressure Switch Fault (£18 )
    Drain Pump Fault (£39)
    Is there anything else I can try before calling the engineer.
    I’ve had the lower panel off and have identified the Pressure switch, but I cant locate the Drain Pump. Also have difficulty removing the dishwasher from its location (tight isnt the word!!!). Drain hose wont be kinked (impossible to get to it)
    Thanks for anything you can throw my way.
    #278951
    Re: SMEG DWI612C Dishwasher – Error Code E6
    Does it actually drain or not?
    gsr36
    I believe it does
    I undid the drain pipe where it connects under the sink and learned that I should have really moved everything out of the way first!!!!
    water poured out so yes – it does drain
    Why it is reporting the problem is beyond me.
    I tried filling it up manually with some additional water to see if it would help with the draining. Currently waiting to see if it still reports the error.
    #278953
    gsr36
    ok – still receiving the error. not sure what else to try.
    #278954
    If you are certain that the machine is pumping out fully, the problem will lie with the water level control system. The code means no drain detected in the time allowed, so the pressure switch may have failed in the closed position, or there is a blockage in the chambers or pipework preventing the switch from de-pressurising.
    Power off before you start pulling panels off.
    gsr36
    folk,
    Dishwasher still knackered and cannot contact the engineer thrugh mail or phone.
    is there alternative engineer contacts on this site?
