Smeg DWI612C E3 error
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Smeg DWI612C E3 error
  • #82480
    ElmleaUK
    Hello all,
    Hoping someone can steer me in the right direction. I’m getting constant E3 errors from our Smeg integrated dishwasher. I’ve tried the “programme button 4 times” reset, and made sure it’s perfectly clean and everything’s rotating as it should.
    It’s a heating error. When a cycle is finished, it feels warm inside the washer, but if I interrupt the cycle the water is certainly never boiling hot. Most of the time it feels quite lukewarm.
    Is there anything I can check with a decent toolkit and a decent degree of tech savvy, or am I best placed to get an engineer out?
    #420028
    Re: Smeg DWI612C E3 error
    if the appliance fills from the hot water then it will feel warm so your fault might still be with the heater fault
    could be
    Heater, broken wires, thermostat or programmer
    ElmleaUK
    Any way to do some diagnosis?
    #420030
    fill it and feel the pipe at the back to see if its warm. if yes then you know where the heat is coming from
    after that it getts difficult you have to check all the components above
