Re: Smeg DWI612C fault lights. Help please!!
Early suppressor is a little three wire cylinder taped into the loom, bottom left. The later one is found in the rear right corner where the mains cable enters.
Solenoid does run at 240v – if the flap opens, there is no need for live testing. You’re looking for poor insulation, water marks, dodgy connections and the like.
PCB can in itself be faulty, they do just fail sometimes.
Tricky one to call exactly……….
