Smeg DWI612C lights 2 and 5 flashing
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Smeg DWI612C lights 2 and 5 flashing
  • #48425
    Simon46
    Been to this one wont reset or cancel program. Lights remain on constant. Disconnected the two hoses from front of sump one to float in base, other to a pressure switch i cannot see. blew in one click then returns to position. is there a different pressure switch that would hold it in this state on the machine? or is it PCB?
    Not seen this fault before. Tried disp solenoid no joy.
    S.
    #296558
    Re: Smeg DWI612C lights 2 and 5 flashing
    see if disconnecting the circ pump clears the jammed pcb, if so there may have been a slight leak (usually from the o rings on the air brake-softner unit joint) causing an earth fault which can cause this. Other than that it will be the pcb.
