Smeg DWI614 – how do I remove air break chamber?
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Smeg DWI614 – how do I remove air break chamber?
Viewing 1 post (of 1 total)
  • #56777
    Kintara
    My Smeg DWI614 leaks at the O rings of the right hand side air break chamber, causing E1 error. I want to change the O rings but cannot see how to remove the chamber. It looks like it is held by the grey plastic ring on the inside of the washing compartment, but I cannot figure out how to remove it. Does it unscrew? Does it prise off? I am stuck on this one.
    Any help appriciated.
    Kintara
    OK a bit more Googling and it seems the part that holds the airbreak chamber (Also called IWMS – Inlet Water Management System) is called a load ring and it seems to have a thread on it (Looking at the photo). So… I think I’ll need the use of a strap wrench..
    Keep you posted.
    Kintara
