Has anyone had problems with these not filling?
I have one that originally had E2 flashing on the display, this was caused by nusiance tripping of the float/overflow switch.
I then replaced the metering tank for one of the new improved ones, i fitted the full kit, nothing left out, wired the new pressure switch and float switch correctly etc.
…but since then it refuses to fill 😯
No broken wires, all valves ok,no blockages, no open circuits, new pressure switch and float switch ok….HELP!
Only thing left seems to be the control PCB..bit strange to play up after fitting a metering tank.
Any help appreciated!
Regards
Ray
