Re: SMEG DWI710 E1 Help Pretty Please
The re-set procedure is specifically to clear a flow meter problem and is not appropriate in this circumstance.
Holding down the button cancels the programme – lights 4 + 5 indicate that the programme is finished.
I suspect that you are describing a blockage. Try setting the programme to the Rinse setting and see if the drain pump runs – this is the first action of any programme. If it doesn’t run, bail the machine out. The drain pump is accessible through the front lower cover.
Power off first.
