Smeg DWI710E1 cannot programme
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Smeg DWI710E1 cannot programme
  • #41024
    alro
    Hi gents
    called on a smeg d/washer DWI710E1 switch on, 1 noen lite and 5 flashing cannot select any programme to work or move to another programme any ideas
    cheers alro
    #268385
    Re: Smeg DWI710E1 cannot programme
    Yup, p3, KNOWN ERROR CODES.
    alro
    Chris
    does that mean to say that resetting of the appliance is wot to do or the error is e1 as the aqua stop is ok , noen 1 is on constant & not flashing but noen 5 is flashing & not on constant i am tending to think of a pcb failure
    cheers alro
    #268387
    Flood protection activated – either there is water in the base, or the pneumatic shut-off has been activated. Either way, it’s a water level issue.
    alro
    chris
    thank for reply no water in base & the micro switch on atiflood is not in op or i can use my screwi and lift it up to operate the pump
    cheers alro
    #268389
    You can flip the switch manually. The problem probably lies in the fill chamber under the right hand side panel. It can sludge up, as can the tubes connecting to the sump. I’d start with a strip down and clean out and see what happens.
