Smeg DWI710E1 D/washer Stuck on Rinse
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Smeg DWI710E1 D/washer Stuck on Rinse
  • #23163
    laurenceuk
    I think this machine is badged as other machines also, like Neff and Bosch etc.
    Opening the door exposes the programming button on top LH side and ON/OFF switch on top RH side.
    It remains stuck on the rinse progamme. Pressing the prog button will not advance the lights at all to other progs.
    Is their a prog resetting procedure or is this a duff programmer. The machine will do the rinse cycle and finish each time the machine starts again.
    Laurence
    #197176
    Re: Smeg DWI710E1 D/washer Stuck on Rinse
    check the dispenser coil Lawrence, just slave on a solonoid valve to prove it.
    #197177
    laurenceuk
    Thanks,
    Nice tip for future ref also.
    Laurence
    #197178
    mowerman80
    Hi dont know if this helps but did you try holding the rinse button down for a few seconds as this can reset the progam and then change the programs. :rolls:
    #197179
    laurenceuk
    Thanks M-Man,
    All this helps
    Laurence
