smeg DWI710E1 dishwasher
  • #27919
    robwash
    Hi, I can select a program and it looks like the lights work but when shutting the door nothing happens. checked door switch and ok. checked also with supply on and facia off. tested 240v at all components. microswitch on door making and ok. I know this is the same as a diplomat and have already done the power on press 4x bit to reset but still nothing. have checked pump and ok and flood switch is down. its all there ….it just won’t start. cheers anyone
    #216089
    Re: smeg DWI710E1 dishwasher
    Have you left it long enough? Is there a beep beep after shutting the door? some of them take ages before doing anything.
    #216090
    robwash
    yes. waited and waited….i’m now older…it doesn’t matter now…thankfully the cux was a nutter so i’m not going back but cheers for reply. rob
