Re: Smeg e9 error code
That error code doesn’t equate to an error as such and shouldn’t be displayed during normal operation. Search the forum for ‘smeg AND reset’ to find the reset procedeure which should sort it. 😉
It’s not unknown for these to display eroneous error codes unfortunately, and resetting is often the cure, but if that doesn’t sort it then you may be looking to replace the pcb(costly)…if that’s the case it would be wise to get an engineer in first to rule out other causes of pcb failure 😉
