Hello,
The cooling fan went on Xmas
, gacked up with grease(??) and subsequently 1 of the 2 thermal fuse blew. Cleaned/fixed the fan & replaced the fuse.
Now every time I turn it on at the wall:
- The (pyrolytic) lock slowly engages. This happens even is the door is open and will eventually disengage after turning off at mains. I cannot easily get to the lock assembly to test.
- All of the elements heat, but not all at once – I.E. when all should be on the fan element isn’t working and when its on Fan Only mode then element works.
My thinking is the main board? But idk – I am going to test the oven elements with a Megga just to be sure its not the elements. Also the rotisserie motor has some carbon charring and isn’t freely moving – interestingly the thermal fuse above the charred motor didn’t blow….
