Smeg FA421X, starter broke on Embraco compressor.
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Smeg FA421X, starter broke on Embraco compressor.
  • #63297
    MarkWW
    Fridge been fine for years, then just defrosts itself overnight, possible door open ? We empty the wasted freezer goods, then switch off to clean. After 24hr switched back on, left for another 24hr to get to temp, just warm air circulating, no frost forming on the coil, all fans & lights fine, however, heard clicking noise near compressor, which is warm/hot, but no noise and no cold air being produced. The starter unit/block, on closer inspection has fused inside,pieces of plastic and a circular disc are shattered.
    Is this repairable please, everything ran fine for years, then sudden defrost = the end ?
    #353355
    spimps
    Re: Smeg FA421X, starter broke on Embraco compressor.
    You should be able to replace,there are also alternatives o the origional.
    Whats the number on the compressor ?
    #353356
    MarkWW
    number on compressor is: EGU 110HLC
    220-240V 50-60Hz
    R134a 1PH
    9.4/9 LRA
    #353357
    spimps
    Had a look around and cant find one,suggest you try http://www.smeg-service.co.uk/smegfabspares.php
    BG
    #353358
    MarkWW
    Thanks for looking, still researching this issue, trying to find other suitable fixes…one is the hard start kit !
    Various universal options, just trying to make sure on compatibility.
    #353359
    spimps
    The RCO kits are good,often use them here.
    From the wattage of the compressor work out bthe hp and fit the appropriate one.they do 1/10th 1/8th 1/6th 1/5th,etc,divide 746watts(1hp) by the wattage of your compressor and the fractional answer will be the size of universal starter/relay kit you need.
    Contact me if you cant find one.
    BG
