Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › SMEG FA550X (Whirlpool) American Fridge Water Problem
- This topic has 9 replies, 3 voices, and was last updated 13 years, 10 months ago by
TeeMyob.
May 15, 2012 at 9:24 am #69479
TeeMyob
ParticipantHello,
Having trouble with a SMEG FA550X american style fridge.
When water is demanded for the ice maker, it also comes out of the door water dispenser and vice-versa. That is, if you request water from the door, it overfills the ice maker.
It is not the valve or the MAIN Module as far as I can tell.
Does anyone else have any experience of this issue?
I do remember some time ago. There was an issue with Kelivinator USA units where the diodes in the door had to be replaced.
Any help appreciated.
TM
May 15, 2012 at 10:47 am #374941ANDYVIVO
ParticipantRe: SMEG FA550X (Whirlpool) American Fridge Water Problem
Hoses or wires switched over on the valve? Swapping the wires should solve your problem I would think.
Regards AndyMay 15, 2012 at 4:08 pm #374942TeeMyob
ANDYVIVO wrote:Hoses or wires switched over on the valve? Swapping the wires should solve your problem I would think.
Regards AndyIt seems that to both solenoid valve there is 17-125volts, even when not in use.
When you or the ice maker requests ice, the water goes to both the water tap and the ice maker at the same time.
So not crossed wires.
TM
May 15, 2012 at 11:00 pm #374943eastlmark
ModeratorRe: SMEG FA550X (Whirlpool) American Fridge Water Problem
no diode on this one, its all controlled by the rear module. Check the resistances of the valve coils first, occasionaly they short out across the terminals from leakages.
May 16, 2012 at 6:52 am #374944TeeMyob
Thanks, might have to try a valve. But if they are getting 240v at both sets of cables?
They will both open!
TM
May 16, 2012 at 6:26 pm #374945eastlmark
but a shorted coil could have blown the rear board.
can you clarify:a) if you draw water through the fountain, the ice maker fills as well?
b) when the icemaker is filling, water also comes out of the fountain (ie this will obviously happen even if no one is operating anything or even around at the time, they just find a pool of water on the floor that has run down from the fountain/dispenser?
c) both of the above.
May 16, 2012 at 7:06 pm #374946TeeMyob
eastlmark wrote:but a shorted coil could have blown the rear board.
C
I have tried a new board and the same thing happens when it is fitted.
Thanks for your replies.
TM
May 16, 2012 at 8:59 pm #374947TeeMyob
C Both of the above
May 16, 2012 at 11:24 pm #374948eastlmark
well, it can only be the front board then? Have you checked the wires in the top door hinge though? wondering if they have broken and shorted out maybe?
May 18, 2012 at 3:25 pm #374949TeeMyob
Thanks.
Have checked the wiring, nothing obvious.
TM
