This may not be a compressor fault, It could be a control fault
From a quick look it seems to have a simple thermostat so you can try something.
there are a number of fridges with similar model numbers some use a hydraulic stat others use electronics. we would need to double check the model on the label
go here and put your model in and you will see https://www.servevastdirect.co.uk/
wait till its not working, open the door gently then tap the thermostat knob firmly. if the compressor bursts into life its a stat problem
did look on smeg site and they want over £100 for the stat but site shop may know of an equivalent
