Smeg Fab32 f32strp3 not cooling
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Smeg Fab32 f32strp3 not cooling
  • #96326
    Dfounde
    i have a Smeg fridge. Freezer part works fine, the fridge won’t cool though.
    ive checked the internal thermostat with ohm meter and it gets a reading.
    right hand side compressor is working and feel it doing something.
    inside fridge I can here it pushing something through but it’s not cooling.
    I have a spare thermostat from a different fridge(think it’s universal)
    any advice?
    #463010
    adv
    has this got 2 compressors then ? one for fridge one for freezer ? it must be very old ?
    #463011
    Dfounde
    Hi yes it has 2 compressors.
    not sure how old it is. I acquired it. Model is s32strtp Fab32… doesn’t seem that old
    any advice?
    #463012
    adv
    need to check if geting a live to the fridge compressor ..from the fridge state ,usually the black wire .. at bottom of start relay on compressor .. if you are . .if not will be the state ,, if you want to check compressor take relay of compressor and check with ohmeter across the 3 pins ,, should get a reading across the 3 .. if not compressor gone , that test is with power off ,, ie mains
    #463013
    adv
    if both compressors are warm to touch .. the fridge one could have lost its compression or lost its refrigerant .. which is not a easy fix these days
    #463014
    Dfounde
    Ok, the there is a reading coming through on the relay.
    i left it on all night last night and it is slightly cooler than it was. But not fridge cool!
    like I say the compressor is running.
    could it be the thermostat? Can I bypass the thermostat? Bridge black & blue feeds inside thermostat?
    #463015
    Dfounde
    Update:
    ive bypassed the thermostat and the fridge is making a normal fridge noise, but not cooling.
    is this likely to be gas?
    #463016
    TrickyRikki88
    Dfounde wrote:Update:
    is the comp deffo running?
    is the discharge pipe hot?
    is the suction pipe cold?
    is the top of the compressor too hot to touch?
    #463017
    Dfounde
    Yes
    warmish
    ambient
    no hotter than the rest of compressor
    #463018
    TrickyRikki88
    Dfounde wrote:Yes
    warmish
    ambient
    short of refrigerant i would say, if the discharge is warm and its coming back ambient sounds like it could be short.
