smeg fan assist oven trips rcd
Home Forums Public Support Forums Help And Support Cooker And Oven Forum smeg fan assist oven trips rcd
  • #62411
    Bronte
    Hi, I am having trouble with my fan assisted oven tripping the rcd. It happens at various points – sometimes when the oven has been on for 20 mins sometimes longer – but only when the fan assistes oven is on. I have been told it is the fan oven element? Any helpful comments/suggestions? thanks.
    #350035
    colly
    Re: smeg fan assist oven trips rcd
    Sounds like an earth fault on the fan oven element .
    This can get worse as element heats up
    Colin
    #350036
    Bronte
    Thanks Colly, Looks like the part is easy enough to get hold of. Can a competent DIY er replace the bit? Will I need any special tools?
    #350037
    colly
    You will be able to replace it ok .
    No special tools required.
    Colin
    #350038
    Bronte
    Have replaced the fan oven element and the problem still exists!!! Any ideas anyone???
    #350039
    Bronte
    Re: fan oven trips rcd
    I have been having problems with fan oven tripping my rcd. After advice with this forum have replaced the fan oven element but the problem still exists! Any other ideas?
    thanks
    #350040
    colly
    There must be an earth fault on one of the other elements.
    Sounds like you may need an engineer to test the oven with a megger
    Colin
