smeg fan oven heating unreliably
Home Forums Public Support Forums Help And Support Cooker And Oven Forum smeg fan oven heating unreliably
  • #15772
    joal
    Hi, I would welcome any advice in diagnosing and repairing my smeg fan oven, model SP9000X/1
    When turned on, the fan and light work as normal but the heat is unreliable – sometimes there is no heat, sometimes just a little, and sometimes it works correctly. Is is the thermostat or something else, and is it something I can order from here and repair myself.
    Thank you.
    #166273
    Re: smeg fan oven heating unreliably
    hi
    is this a problem with the main oven or the small oven ?
    most probable cause is either a faulty selector switch or thermostat as its intermitent then it would be best to get an engineer to look at it.
    bryan
    #166274
    joal
    Thank you for your advice. It is the main oven that has the problem – the small oven and the grills in both ovens are still working correctly. Does this change what the fault could be and your suggestion of calling an engineer?
    Thank you.
    #166275
    Dave_Conway
    Yes, I’d go along with Bryan on that, selector or thermostat normally.
    You should find an engineer by following the repairs@ link below 🙂
