smeg fault codes not in manual
Home Forums Public Support Forums Help And Support Dishwasher Help Forum smeg fault codes not in manual
  • #46102
    jez33
    hi
    we put our smeg dishwasher on lastnight and for the 1st time in a long time it didnt finish the program.
    the 2 outer lights are off and the inner 2 lights are on,.
    any one know what this fault is ??
    #288241
    We will need at least the model number to help.
    jez33
    Re: smeg fault codes not in manual
    sorry foregot..
    here it is
    type- 10045
    model no- dwf 64 sse
    #288243
    It sounds as if it’s stuck in the test cycle, either that or there’s a weird fault I can’t see listed which will often point toward a board failure on those machines.
    To reset it…
    Switch off the machine
    Repeat the procedure to restart the test cycle (open the door and switch on the machine and within 3 sec pressĀ 4 times the button “Start/Pause”)
    switch off the machine
    The test cycle is reset, it is possible to select any programme.
    If that doesn’t clear it then it’s a pukka fault and, as I said, probably with the PCB although there are other possibilities.
    HTH
    jez33
    ok.
    ill try that when i get back from work and give you results then .
    cheers
    #288245
    jez33
    the 2 outer lights are lighted up now and not the 2 inner ones, it also wont reset.
    any one got any ideas?
