Smeg Fridge running out
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Smeg Fridge running out
  • #11952
    monkeytrousers
    I have a smeg retro style fridge and its running out -there is always a pool of water around the bottom. the seal doesn’t seem to be sticking well on all sides when the door is shut -I wonder if anyone has had this problem or if you know how much a new seal is to buy and fit. Many thanks
    #147279
    Del
    Re: Smeg Fridge running out
    Try checking the defrost water channel that leads to the defrost drain hose on the inner rear wall of the fridge.
    You will probaly find its blocked with crud, just probe it with a flexible pipe cleaner or straw to clear it out.
    HTH
    Del
    #147280
    monkeytrousers
    Thank you so much! No water seen for at least 3 hours now so i think we have a success! Thanks for taking the time to help out. Very much appreciated.
