Smeg Grill Element Upper Support
Home Forums Public Support Forums Spare Parts Help Smeg Grill Element Upper Support
  • #99464
    smeg peter
    Ive recently purchased a replacement upper support for my smeg oven (890660173) and bought the recommended fixing screw (899371357) at the same time. Both items have arrived but the fixing screw does not fit the support, it is too fat. Is there an alternative screw that does fit?
    #476508
    For what model?
    smeg peter
    Its for a model DOSP6390X. The screw provided doesn’t even fit the part, let alone the oven I need to fix it to.
    #476510
    On that model, they altered those.
    899371357 is correct but the note on Smeg reads:
    [TABLE=”align: center, cellpadding: 4, cellspacing: 1″]
    [TR]
    [TD=”align: center”]Modifications MC0000000012874[/TD]
    [/TR]
    [TR]
    [TD=”colspan: 2″]INTRODUCED NEW TILTING HEATING ELEMENT SUPPORT.[/TD]
    [/TR]
    [TR]
    [TD=”colspan: 2″]THE NEW SUPPORT REQUIRES A DIFFERENT FASTENING SCREW: ON MODELS MANUFACTURED BEFORE THE CHANGE, WHEN THE OLD SUPPORT IS NO LONGER AVAILABLE, IT WILL BE NECESSARY TO ORDER ALSO THE SPECIFIC SCREW 899371357.[/TD]
    [/TR]
    [/TABLE]
    Component Interchangeable
    smeg peter
    I’ve done exactly what the instruction above told me to do. What I’m saying is that the screw that is recommended does not fit the support. The screw is too fat for the hole in the support.
    #476512
    I have no idea, that’s what the Smeg factory system says is correct.
