Shaft on the front r/h/s regulator has broken off in customers hand….. is the complaint.
Decided to order a pattern part as the Smeg was too expensive from connect (816810066 used ELE4117)
Fitted it fine even though some spade postions were in a different place so matched up the numbers, as usual in these cases…. it came on great but didn’t really cut itself off until the second test – put it back together and NOTHING, didn’t heat up!! Re-checked connections but still nothing.
Went back with a second ELE4117 today and the same thing happened…. is it me or is something else wrong?
Customer complaint was still only about the broken shaft and not its operation.
Confused…
