Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › smeg intergrated dishwasher fault codes
- This topic has 6 replies, 4 voices, and was last updated 20 years, 5 months ago by
sparkys.
November 4, 2005 at 12:12 am #13039
sparkys
Participanthi, does any one know what left to right led 4& 5 flashing means as this does not seem to be a normal fault
November 4, 2005 at 9:17 am #152772Dave_Conway
ParticipantRe: smeg intergrated dishwasher fault codes
It’s not, it’s one of those odd one’s that in theory doesn’t exist.
Check the dispenser solenoid as these do odd things to the PCB’s and it might be worth a reset.
November 4, 2005 at 9:27 am #152773NWAR
ModeratorRe: smeg intergrated dishwasher fault codes
Sometimes the machines will go on to this after first displaying another fault. Run the machine through a cycle again to see where it stops and it should display the underlying fault code (although sometiimes not for long).
Craig
November 4, 2005 at 8:00 pm #152774bobokines
Had the same today. Mine was a Teka branded model. It was a blocked metering hose system. This can sometimes be cleaned with your trusty syringe and a length of pressure hose:
Remove the black non-return valve under the filter then suck and blow some water through the pipes. However, it woiuldn’t work for me today and I had to strip it down as the gunk was in the metering chamber inside the right hand side wall.
BobNovember 4, 2005 at 8:54 pm #152775NWAR
TDW59.2FI?
It’s almost a certainty that the air break will be clogged if it’s over 2 years old.
Same problem as the Smeg branded ones but with cheaper customers 🙄Craig
November 6, 2005 at 7:44 pm #152776sparkys
ParticipantRe: smeg intergrated dishwasher fault codes -MODEL DWI 45
HI, TRIED ALL YOUR SUJESTION NO RESPONSE, HOWEVER, WHEN I FIDDLED WITH THE ON/OFF BUTTON AND PROGRAM SELECTOR, THE APPLIANCE BRIEFLY LIGHT ON 1 & 5 (FLASHING) ANY IDEAS ! DOING THIS ACTIVATED THE PUMP THEN THE VALVE – (NORMAL OPERATION) THEN STOPPED WITH AGAIN 4&5 FLASHING
November 6, 2005 at 7:57 pm #152777Dave_Conway
If lamp 1 was on and lamp 5 was flashing it’s an anti-flood detection (flooded base).
I would remove the whole air break and flush it right out (if you haven’t done that already).
Unless there is a leak in to the base of course 😉
