Re: Smeg matrix blockage
Gerry, if you could post the model number then we might be able to help a bit more.
gerry4 wrote:could you give me the sequence of evens to remove and replace this unit
Unfortunately no, we can’t. We can give you some general pointers but when things become technical we can’t give you a blow-by-blow account of how to do it.
Regardless of your own disclaimer any other browser of this thread would receive the same instructions and they might not be so forgiving.
Generally it’s a side off, get a little wet job that only requires a screwdriver. The hardest part is usually getting the machine in and out.
