Smeg Mod 5 (or S)980x
  • #27351
    robbra
    Ser. N20929885
    Need a mains terminal block and Smeg insist its Part 825170033 which is a long one with terminals on top like Belling but the one I want the cable comes in the bottom and with a clamp and the earth plate is attached to the frame.Hope this makes sense.
    Can anyone help?
    #213729
    Re: Smeg Mod 5 (or S)980x
    Something like that?
    825170164
    robbra
    Exactly Chris
    Why couldn’t Smeg get this. So unhelpful and insisted it was the other block.
    Thanks again
    Rob
    #213731
    robbra
    Hi again. Have been told it is obsolete! Anyone know where I can get one?
    Rob
    #213732
    robbra
    Help, driving me nuts.
    Fitted a new selector switch which has 9 terminals, not 8. Like for like gives everything but grill, swopped 6 to 7 and got grill but no heat on fan oven but ok on conventional. Tried lots of swops but apart from blowing a few fuses the fan oven heat refuses to work. Any help most welcome.
    Thanks.
    Rob
    #213733
    Check your mail Robbra. 😉
    robbra
    Thanks Ken, will go armed with that but it has the eight terminal switch whereas the replacement is nine terminal but at I will be able to check where I may have gone wrong. Thanks again
    Rob
    #213735
    robbra
    Ken,
    Just to say thanks, it really helped to sort out. Three of the wires were relocated onto different terminals but she is cooking again!!!!
    Rob
    #213736
    No worries Rob, you’re welcome.
