When the machine is set to do a normal load (4th light from the left) it drains any water (draining fine) then it fills from the cold water inlet pipe (for about a minute) then it drains again – all this takes about 4 minutes then it stops! the 1st, 2nd & 3rd lights (from the left) are flashing and the 5th light is on constant. Can anyone advise whether I need a ‘man that can’ or it’s simple enough for my husband to tackle? Thanks for any help you can give.
