smeg oven element
  • #10527
    I have a A1 range cooker (90cm) stainless steel. (approx 6 yrs old)
    I think one of the heating elements has gone. the oven doesn’t get to temp when using the fan option with the little line underneath.
    The grill element, thermostat and fan are working fine so it must the other element (fan element?) – i take it there are only two????? 😕
    Any help gratefuilly received
    Many thanks
    #140471
    Dave_Conway
    Re: smeg oven element
    The fan with a line underneath should be fan assisted with base element only (there are three elements, the base one is hidden).
    The fan assisted (proper) mode is normally a circle around the fan symbol.
    Fan element is by far the most common failure though on any fan assisted oven, if yours has failed, it’s this one in the shop:
    http://www.ukwhitegoods.co.uk/modules.p … cts_id=332
    #140472
    thanks dave
    sorry yes, the fan does have a circle around it and a line underneath
    the book says to use this one most commonly as the oven doesn’t need preheating
    i take it there isn’t an option to select the base element on only?
    i want to make sure i order the correct one
    thanks again
    andrew
    #140473
    Dave_Conway
    Theres should be a setting with fan element only (circle round the fan) if the fan element has failed, it will be cold.
