Hi all,
The function selector On my Smeg S10XMF recently broke, bought a new one from ukwhitegoods and noticed when it arrived that it had one extra terminal than my existing one, I wired it up the same as the existing one leaving the additional 9th terminal empty and when I turned the oven back on it tripped the RCD and blew the fuse in the oven plug.
I decided to put the old function selector back in so I could at least use the oven, all be it without being able to switch function but there is now no power to the oven….
Something has obviously blown inside the oven due to my incorrect wiring pattern, what would be the best route for diagnosing this? As far as I’m aware there’s no internal fuse so what else could have blown?
Ive since found out the correct wiring pattern for the new selector
any help much appreciated!
Duncan
