Smeg oven – missing symbols
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Smeg oven – missing symbols
  • #100028
    Cee_help
    I’ve recently moved into a flat and the oven is missing symbols so I’m unable to tell which setting the oven is on. I have tried contacting smeg directly but had no response and don’t have the manual/can’t see model type on the oven to google it.
    Please help
    file was too big to upload so here’s the pictures
    https://ibb.co/XxFFD7J
    https://ibb.co/ysR6c7Q
    #478955
    that one is fairly simple
    left knob is a minute timer you can either set to manual ( turn anti clock to the hand) or turn it right to the length of the cooking time
    middle knob is the thermostat. you could buy an oven thermometer to find where the important places are
    right knob is function
    from what i can see going clockwise defrost, full grill, half grill
    dont know the rest so you will have to experiment , open the door turn to manual and turn thermostat up. then turn knob anti clock wise and see if the oven fan turns on and heat comes out of the back of the oven. if yes you have found the main oven
    if you find model, Should be round the door if not unscrew oven as i think its repeated on the frame , i may be able to find the manual
    dave
    #478956
    Cee_help
    Hi, thank you. I probably should’ve been more descriptive. It’s the function I can’t figure out, just hoping someone else has the same model and can advise.
    #478957
    seen loads of them but cant remember model
    you need to find that and will see what i can do
