Smeg oven model F67
  • #52728
    spanner51
    No heat in oven
    No fan
    Oven lamp on all the time ( even when selector is off )
    Cooling fan OK
    No lit neon
    I suspect selector switch, can anyone help, or send me a wiring diagram
    Cheers
    Graham
    #312880
    chezza
    Re: Smeg oven model F67
    cant find this as a model ; check timer first . ( often smeg ovens have a door micro that operates the cavity lamp so this may be a seperate issue ? )
    other than that, agree probably selector switch …. full model will be handy
    #312881
    spanner51
    Thanks chezza
    model F67
    type NO66K
    s/n N421 65530
    It was hard to pull out, stuck with crud, so I pulled on the door to get it out. The door came off in my hand, and was difficult to get back on. Customer said he never uses the timer, thats what made me think off selector switch.
    There was also a transformer in the top, but couldn’t see what it was for. That’s why a wiring diagram would be handy
    Cheers
    Graham
    #312882
    johnsdad
    door microswitches also interrupts fan and elements
    #312883
    Assuming its a F67-7 its an electronic control, no selector switch on that one and the transformer is for the pcb. No wiring daigram available, sorry.
