Smeg Oven Model: SUK90MFX
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Smeg Oven Model: SUK90MFX
  • #21819
    Dowpete
    Smeg – Range – Electric Oven.
    Model: SUK90MFX
    Type: C9N0xx
    CE 51AU1686
    Hi there, my oven above has stopped working when I put it on fan assisted mode (i.e.: top and bottom element do not heat). It does seem to work when just on non-fan mode, but doesn’t quite get up to set temperature.
    On reading various other people’s problems it seems that it may be wise to get a pair of new fan elements. But my worry is that even when it’s not fan assisted mode it isn’t reaching the set temperature. Should I replace top and bottom element too?
    If you have any advise or help, I would be most grateful.
    #192637
    Na, it’ll just be the fan element. In fan oven mode only the fan element/s are energised.
    An email to spares@ukwhitegoods.co.uk will get you prices etc.
    gegsy
    Re: Smeg Oven Model: SUK90MFX
    Is the oven door sealing tightly I wonder? It should close with a THUD and have no “play once closed.
    Dowpete
    gegsy wrote:Hi
    Hi Greg,
    The oven door is sealing tightly, it does close with a THUD and there is no play in the door.
    Thanks,
