smeg oven not working
Home Forums Public Support Forums Help And Support Cooker And Oven Forum smeg oven not working
  • #82413
    fever7
    I am a bit stumped now. My oven stopped working. No temp light or anything.
    After some testing i have found that everything works fine if i bypass the thermal cut out at the back. I have even replaced it with a new one but still doesn’t work. Yet when i disconnect and bypass it, all is fine.
    Any help please
    #419775
    Re: smeg oven not working
    You’ve not fitted the correct part I would think. You’ve sussed the fault for sure but the part you replaced it with is wrong. Try and source the right one.
    #419776
    fever7
    Do you know if it should be normally closed or open? The thermal cut out.
    #419777
    Normally closed.
    #419778
    fever7
    I am pretty sure it’s the exact same part. Why would the cut out kick in instantly on turning the switch to on? When the on switch is turned to either oven or grill the temp light flashes on for like a millisecond. Like it’s trying to come on but something is cutting it out I.e (thermal cut out)
    #419779
    Well you didn’t tell us the model number of this Smeg oven but generally a TOC only operates when temperature exceeds the pre-set limit (say 180Celsius). So from cold ( i.e on switch on) there’s no way that’s going to happen to such a part. So I have no clue what’s going on there TBH. 🙁
    #419780
    fever7
    Se335ss/1 is the model number. Apologies, my mistake.
    #419781
    fever7 wrote:Se335ss/1 is the model number. Apologies, my mistake.
    In that case the correct TOC is THIS one.
    #419782
    fever7
    I have read conflicting messages about whether they should be normally open or normally closed.
