Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › SMEG Oven – SE 375 MSX – Problems
- This topic has 8 replies, 2 voices, and was last updated 20 years, 9 months ago by
Hazel.
June 20, 2005 at 2:33 pm #10238
Hazel
ParticipantHello Anyone,
Above oven is approximately 5 ish years old – and was in the house we moved into a few years ago.
Several things are worrying me: –
1. Don’t know if this is normal but the door seems dangerously hot when the oven is on. Don’t have kids, otherwise this would be a major problem.
2. It seems to smoke (as in grease/food rather than electrical) every time I use the oven. It’s so bad that I have to have all windows open (kitchen is quite small) and can’t use it if we have guests. I had it professionally cleaned about 6 months ago and it was fine for about 2 months. It’s bad enough with the fan-assisted selector control, but if I ever just use the “regular” control, it’s just awful.
It’s kept pretty clean and I just don’t know what the problem is.
Help!
Any suggestions?
HazelJune 20, 2005 at 3:10 pm #139175Simon46
ParticipantRe: SMEG Oven – SE 375 MSX – Problems
Does it appear hotter than usual/burning food/taking longer for the light to go out when it has reached temperature?
Regards
SimonJune 20, 2005 at 3:42 pm #139176Hazel
Hi Simon,
I think it’s always been this hot (and has been the bane of my life since moving in here).
Yes, it does tend to burn things – especially cakes – they go black around the edges before the inside is cooked. I do reduce the recommended cooking temperature when using fan-assisted. I have started having to cook some things covered in foil just to avoid the smoking and burning smell.
It takes about 20-25 minutes to heat the oven up to 180 dg C. I’m not sure how quickly it’s supposed to heat up but that is another annoyance. 😕
Would welcome your comments/suggestions.
Thanks, Hazel
June 20, 2005 at 3:55 pm #139177Simon46
Hazel
If you know anybody with an oven thermometer to check temp selected against actual temp. If the fan in the oven is spinning o.k. i suspect the oven to have a temperature control fault. Idont know if there is one in your area but John Lewis sell them. Otherwise cliking on Repairs@ on LHS of screen may be able to help you regarding fixing it.Regards
SimonJune 20, 2005 at 4:05 pm #139178Hazel
Thanks for that Simon,
I’ll try and get hold of an oven thermometer. Am in London so plenty of John Lewis stores around.
Re: the fan – it sounds like it’s spinning – as in, a totally different sound compared to just using the convection oven setting.
Do you know if a temperature control fault is serious (expensive) to fix – if that is the problem?
Thanks again for your replies.
HazelJune 20, 2005 at 4:12 pm #139179Simon46
Not that expensive but cheaper than new oven! I had a lady who was so pleased with her repair she kindly donated some hot pasties to me. 😀
Simon
June 20, 2005 at 4:36 pm #139180Hazel
Donating hot pasties sounds like one satisfied customer Simon!! Bet she wouldn’t have made them for you on a day like today though 8).
I have no idea how much new ovens are – would a repair like this be £100 or £100’s. Sorry to ask – I know you can’t be specific but a rough idea.
Will try the thermometer thing and take it from there. What you have said makes sense though. Is 20-25 mins to heat up 180 deg C longer than it should take?
HJune 20, 2005 at 4:48 pm #139181Simon46
All depends on labour charge in London. I would do it but in Cheshire. Try thermometer first and get back to us. smoke usually means over heating unless there is a lot of fat from grilling.
S.
June 20, 2005 at 4:50 pm #139182Hazel
Thanks, will do. 😀
