SMEG OVEN SUK62MFX – Thermostat Problem?
Home Forums Public Support Forums Help And Support Cooker And Oven Forum SMEG OVEN SUK62MFX – Thermostat Problem?
  • #8250
    The temperature control on the bottom oven does not seem to work anymore. I just gets hotter and hotter regardless of the temperature set although the light does swith off eventually indicating that the oven has reached its temperature. Could this be a thermostat fault?
    #127645
    clivejameson
    Re: SMEG OVEN SUK62MFX – Thermostat Problem?
    yep…that would be the stat at fault!
    If you post again on the public parts enquiry stating the make model and serial number then others will find a part number and price for you.
    #127646
    Thanks Clive. I’ll do that.
    #127647
    Hi Moochie,
    Dave’s on holiday and I’m out the office this week but you can either mail Jess on spares@ukwhitegoods.co.uk and she’ll price it for you or Mark may be able to tell you later.
    Can get you a price tommorrow but be warned its not a diy job by any means. If you are going to get someone to do it, then they will be able to supply it at no risk to you.
    try: click here to try our repairs@service
    Mark.
    #127649
    its £29.41 inc vat & p&P.
    E mail me at: mark@anglia-electrics.co.uk should you wish to order.
    Also, could you just confirm the position of the thermostat knob, is it the one nearest the side of the cooker? as I cannot id the lower oven stat from the picture.
