Smeg oven SUK91cmx5 One of the two fan elements power is down
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Smeg oven SUK91cmx5 One of the two fan elements power is down
  • #100970
    Simon1066
    Hello Oven experts
    I have a SMEG SUK91cmx5 range oven.
    One of the fan elements is not working.
    So I popped in a new one like normal and it is not working.
    I swopped the power and the element is good, so its the power to it.
    Is this now the PCB board?
    We had, had a power cut not sure if this could have made any difference…
    Just want to check if it is something else or time to retire the 15year old oven..??
    Second fan element and all the other functions are all fine..
    Kind advise please
    Many thanks for your help
    Simon
    #482874
    Simon1066
    PS
    I’ve switched the jacks on the PCB to the two fan elements and this makes the new element work.
    So it looks like the top white “Finder” Relay looking widget has failed.
    Thanks for the advice
    #482875
    will be the relay its a common problem
    might get away with a new relay otherwise its a new board
    Simon1066
    Thanks Dave, I’ll give it a go, Cheers and thank you for your help on this and many on the forum!! Good guys rule!!
