Good evening. I’m after some advice on this oven.
Its randomly stopped reaching its temperature when set. (Orange light flashes continually, without reaching solid light.)
the cooker seems like it continues to heat. Often burning food.
would anyone know if the thermostat is the problem, and where to buy a replacement part online?
many, many thanks in advance.
Forgot to say, that it started by the fan setting instantly reaching temp after 10 secs. Sounded going off and light staying solid but very little heat. When on normal oven setting it continues to heat without light going solid.
My best guess, the potentiometer is the problem but, it is guess and to find the correct part or modification I’d need the serial number as there are changes to that one.
The sensor is also a possible as is the board but the latter less likely.
Very hard to diagnose without a bit of skill, equipment and know how.
