smeg oven temp fault
  • #77788
    smeg oven se335wh-5
    serial 5323556
    fitted a new thermostat to this oven from smeg (gen part)
    customer is complaining temp is too low
    been out and with 3 thermometers inside oven at various positions measured temp
    set knob to 220 degrees oven does not get over 200
    looked for adjustment on stat to tweek a bit but has none
    any thoughts
    dave
    ps emails smeg and got
    Thank you for your request,
    Sorry but due to company policy i cannot advise how to dismantle or repair any appliance. if you are unsure of how to complete the repair you should contact a local engineer to complete the repair for you
    very helpfull
    #403406
    Re: smeg oven temp fault
    electrofix wrote:smeg oven se335wh-5
    serial 5323556
    any thoughts
    dave
    very helpfull
    What was the original fault? Same thing at a guess? Assuming they are using fan setting, check it has the correct element in it, if its a multifunction oven then check both elements are working. Is the thermostat pilot light going out at 220 (set), 200 degrees (your temp reading) degrees? If the light is not going out then suggest a clamp meter to monitor the current drawn is constant and not cutting in and out from a bad connection somewhere other than the thermostat. Also check the door is shutting tightly- not worn out hinges.
    Have plenty of complaints of ovens not hot enough but a thermometer check using a thermocouple over, say as 30 minute period, plotting the temps every 2 minutes or so usually prove it is working correctly.
    there is no thermostat adjustment.
    #403407
    thanks for your thoughts in reply
    “was this original fault” think so but element was changed first. customer fitted both parts but stat was supplied by us. part was gen stat from servast cant speak for element as he got it from another local firm who told him it was a genuine smeg part
    light was going out when set at 220 which suggest element is ok and working (element is normal round fan element)
    watch light go on and off for over 30 mins to let it settle but still below 200
    dave
