still sounds like an element
one of the elements has got an earth fault. you would need to check the element to earth with a multimeter or megger but if you have neither .
try either
a disconnecting all the elements, make sure all wires cant touch , then turn on and see if it trips. If yes cant be elements. If no reconnect the elements one at a time and see when it starts tripping
or disconnect one element at a time and see if it stops tripping
