Smeg ovenSE210EB-5
  • #49467
    robbra
    Hi all,
    have this oven, only thing working is the cooling fan and lamp, everthing else has live to both sides.
    Have checked the door switch, stat, overheat stat, and selector switch seems fine. The clock/timer is on manual, could this be the problem. There is also a type of resistor on the back but not sure what this is for.
    I’m lost on this one so any help appreciated.
    Rob
    #299988
    Alanj
    Re: Smeg ovenSE210EB-5
    Hi Robbra,
    probably the selector switch, contacts burnt out. Sometimes not easy to see. 🙁
    Alan
    #299989
    robbra
    Thanks Alan,
    Did try the selector but it is a so and so to check
    Rob
