SMEG PL 312 S Super Silent – It blocks and to finish washing
Home Forums Public Support Forums Help And Support Dishwasher Help Forum SMEG PL 312 S Super Silent – It blocks and to finish washing
  • #8288
    SMEG PL 312 S Super Silent – It blocks and to finish washing I’ve to turn the program wheel manually six or seven times.
    The program wheel is the handle you turn to set the washing program before starting the washing.
    What is the problem? How much will cost to repair?
    #127837
    Where does it stop, which is what I assume you mean?
    There’s no hard and fast rules and we may be able to indicate the problem but not give you an exact cost to repair.
    kwatt wrote:Where does it stop, which is what I assume you mean?
    It blocks very often. It blocks about 10 times if I set the maximum washing program. If I set program number four it blocks 3 or 4 times. During R it doesn’t block…
    #127839
    Could be any one of a number of things I’m afraid and I’d have to recommend an engineer for you in this case.
    Try Repairs@ and see if there’s someone in your area, the link is <<<<<over there.
