Can anyone shine a light on this little beauty:
Smeg SUK91 range cooker, the type with two fan motors and two fan elements in the oven.
One fan element open circuit (no obvious short), replaced, now only one will get 240v, if you disconnect either the other will get the power but not both together. I have printed the wiring diagram off and both appear to get their power from the selector switch and the small relay pcb. Both of these appear to be ok.
I would suspect the pcb but both relays seem to energise ok.
Baffled 😕
