SMEG Range Oven With LPG Conversion Not Working
Home Forums Public Support Forums Help And Support Cooker And Oven Forum SMEG Range Oven With LPG Conversion Not Working
  • #12881
    freddix
    I’m confused. We have a SMEG Range oven, with the hob converted to run on LPG (the correct jets have been installed). The hob has been working fine for the last 6 months, but the other day could not get any flame from burners. Changed the LPG cylinder as this was getting low and in cold weather the pressure can drop. So now a new 47kg LPG cylinder and the burners are still only just functioning.
    We have done nothing (100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}) to the supply in terms of damaging pipe work and made no adjustments to the cooker.
    Does anybody have any ideas?
    Thank you
    Freddix
    #152070
    Graeme
    Re: SMEG Range Oven With LPG Conversion Not Working
    Checked the regulator on top of the bottle ???
    #152071
    freddix
    Graeme,
    No I haven’t. But do the regulator wasn’t touched (prior to changing the cylinder). Can they suffer from a mechanical failure?
    Thank you.
    Freddix
    #152072
    Dave_Conway
    Freddix, sorry we can’t advise on this I’m afraid legally.
    Please call a Corgi registered engineer to help resolve the problem. You should be able to find one registered to carry out LPG work here:
    http://www.corgi-gas-safety.com/section … taller.asp
