Smeg SE2640TC1 ceramic hob fault codes
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Smeg SE2640TC1 ceramic hob fault codes
  • #84635
    Hello does anyone know what this fault means on the above Smeg hob, it comes up after about 10 minutes, thanks
    #426350
    Re: Smeg SE2640TC1 ceramic hob fault codes
    10 minutes in use or just powered up for 10 minutes? Think that is a overheat error.
    #426351
    Its after it has been on for 10 minutes, if its an overheat is that a board issue ?
    #426352
    most likely, assuming the install has been ok up to now? The sensor for overheat is on the pcb, lets face it, there are only the rings and a pcb on that one so not much else it can be. If there is a draw full of silver cutlery immediately below it it may be worth giving it a go with the draw out.
    How many rings are on when it fails? all or just one?
