smeg se335ss-3
  • #59210
    simonb
    looking for oven element for above, iv been given part number 806890589 from unreliable source so unsure, also if anyone can find the right part number any lower cost alternatives available as got a feeling this ones going to be pricey?
    have looked on qualtex no joy.
    simonb
    #337367
    Re: smeg se335ss-3
    if its got studs then its 806890386 if its single screw in the centre mounting then its 806890656 its a 2700w this one.
    #337368
    simonb
    Re: smeg se335ss-3
    thanks for speedy reply iv been to see this not sure exactly what the single screw in centre mounting is??, it had what looked like 5.5mm or 5.0mm bolt either side holding element in place to cooker body,not the usual screws on connections side think it had earth tab in centre?? does that help distinguish between the two possibilities?
    #337369
    simonb
    Re: smeg se335ss-3
    have found it on masterpart viewing different pics from your part numbers, thanks 😛
