Smeg SE398X Oven
  • #6695
    Hi there,
    I just bought a flat and there is a Smeg SE398X oven installed. Unfortunately it has some parts missing for reasons unknown, so I have bought them with a mind to intalling them myself.
    The parts:
    2 x knobs & bushes easy to fit
    1 x programmer/clock part # 29617 – this is the problem. There are four blades on the clock, and four blade plugs on the oven. On the clock, two blades are marked N and L respectively and I assume these are neutral and live. The other two blages are part of a ceramic block on the left and it is not marked which is which.
    The 3 wires with plugs on the oven are as follows:
    One is a double wire that is orange coloured and I would assume it is the live one.
    The other two are white and one is a double wire with one lug on the two wires, the other is one wire with two plugs on it a few inches apart.
    If someone could tell me what to plug where I should be up and running – i’ve already spent £200 on the parts.
    Thanks in advance,
    Julian
    #119090
    Dave_Conway
    Re: Smeg SE398X Oven
    Julian, due to EU legislation and manufacturers copyrights we are unable to give you that sort of technical information, sorry 🙁
    Please let us know your postcode as we may be able to offer some help by way of an independant engineer who is also a Smeg agent and will have that technical info available to them.
    Regards.
    #119091
    Damn, that’s what Smeg said. My postcode is Finsbury Park, N4 3LJ. Thanks anyway.
    #119092
    Dave_Conway
    From the directories for you:
    F.F.R. SERVICES
    21 BERRY LEYS
    LUTON
    LU3 3NQ
    TEL : 01582 752712
    FAX : 01582 505402
    The guy’s name is Brian, he should be able to help.
    #119093
    Thanks for your help. I’ll give Brian a call and see how I go…
