Re: smeg single oven stat
its a rectangular white ceramic block about 2″ long (ish) with 2 spade tags on it, im assuming its classed as a cut in for the cooling fan, the cooling fan on this model is (looking from the back) at the top left and the block is just next to it on the right.
i wish id took a picture now.
the original problem with this model is that the cooling fan has been staying on (for days if left) but as usual it was ok when i went, so i guess the stat was not opening as it cooled down..
hope this helps in my quest 😉
cheers paul
